BookmarkSubscribeRSS Feed
aniy
Jun 20, 2014
Loading file from URL, how to refresh?
Hi All,
I am trying to read some data from an xml file on a server. I can load the file using loadtextfile() and then I use parse xml to get the data and everything works fine. However, if I don't close the JMP session the file that I load is just the same one over and over (it is updated every second on the website and has a timestamp, that is how I know). I understand that JMP uses internet explorer and it ie just gets the file from the cache when it recognizes the url. How can I get it to "refresh" every time I load the same url?
Thank you for your help!
Ani
1 REPLY
aniy
Jun 20, 2014
Re: Loading file from URL, how to refresh?
OK, so I found the solution for this: I opened internet explorer and went to settings>general> browsing history>settings> check for newer versions of stored page and selected "every time I visit the webpage" ("automatically" was selected previously). Now I get the new file every time I load the url. Hope this will help someone who has a similar problem in the future.
Ani
