Eduardo
Load data to a google sheet using JMP
Hello everybody,
I was wondering if it was possible to load data to a google sheet using JMP. I'm running a script, it generates some numbers, and I would like those numbers to end up in a google sheet. Any ideas on how to do this?
Cheers,
Eduardo
Re: Load data to a google sheet using JMP
Hi Eduardo,
You can save the JMP data as an Excel file or a CSV file.  In Google Sheets, open a blank table.  Now, import the data using File->Import file from a known folder and select "replace sheet" to replace the blank sheet with the import data.
Brian Corcoran
JMP Development
FN
FN
