News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
mazook
Load CSV from variable
We have a use case where we call Run Program, and the result is a CSV formatted string. Basically, Run Program is running an application which fetches a remote file in CSV format. I know you can write the CSV to the file system, and then read it to a data table from the file system, but is it possible to read the CSV string in memory from a variable, directly to a datatable?
Craige_Hales
Staff (Retired)
Re: Load CSV from variable
This example uses the dos echo command to send a small CSV file back to JMP. It also passes a blob, rather than a filename, to the open function.
csvdata = Run Program(
    Executable( "CMD.EXE" ),
    Options( {"/a", "/q", "/c echo a,b,c&echo 1,2,3&echo 4,5,6"} ),
    ReadFunction( "blob" )
show(blobtochar(csvdata));
dt = open(csvdata, "text");
When the open function sees a blob rather than a filename, it depends on the 2nd parameter to find out the type of data. CharToBlob will convert the text you got back from RunProgram to a blob, or you can get RunProgram to give you the blob directly as shown above.
CSV loaded into JMPCSV loaded into JMP
Craige
Craige_Hales
Staff (Retired)
Craige
