ram_asra_gmail_
List box ignores the duplicate items from list !!
Hi all, below is simple code where i print two list using listbox. in list "Perf_cal", item 2 & 3 are same. so when i run below jsl  only item 2 or 3 is printed along with other. What i need is to print all items (8 in this case) in the list without removing any duplicates.
Thanks
newwindow("new",
Perf_cal = {"101.6", "100.8", "100.8", "100.2", "101", "101.8", "100", "99.2"};
Perf_item = {"a", "b", "c", "d", "e", "f", "g", "h"};
perf=hlistbox(listbox(Perf_item,width(20),nlines(8)), listbox(Perf_cal,width(50),nlines(8)));
ih
ih
Re: List box ignores the duplicate items from list !!
I am not sure about the specific list box question but I wonder if a table box would accomplish your goal.
New window("new",
	tb = Table box(
		String Col Box( "Item", Perf_item ),
		String Col Box( "Cal", Perf_cal )
tb << Set Selectable Rows( 1 );
tb << Get Selected Rows;
ih
ih
New window("new",
	tb = Table box(
ram_asra_gmail_
well, to use string col box, table box is not necessary. i did not use string col box, bcoz, individual items are not slectable. But thanks for lookin at it.
ih
ih
The table box and << Set Selectable Rows message is what allows you to select individual items.  Depending if you want to select the item and cal together, here are two ways to build the window:
Names Default to Here( 1 );
New window("new",
	H List Box(
		tb1 = Table box(
		spacerbox( size( 10, 10 ) ),
		tb2 = Table box(
		tb3 = Table box(
		<<Padding(5)
//Make rows selectable
{ tb1, tb2, tb3 } << Set Selectable Rows( 1 );
//Get selected rows
tb1 << Get Selected Rows; //Returns [1] for the screenshot above
tb2 << Get Selected Rows; //Returns [2] for the screenshot above
tb3 << Get Selected Rows; //Returns [3] for the screenshot above
pmroz
Another approach you can do is to make perf_cal unique by prepending perf_item to it.  When a user makes a selection you'll need to strip off the first three characters.
perf_list = {};
for (i = 1, i <= nitems(perf_cal), i++,
	perf_list[i] = perf_item[i] || ". " || perf_cal[i];
New Window( "new",
	perf = H List Box(
		List Box( Perf_list, width( 50 ), nlines( 8 ) )
