News
On June 1, we’re asking you to select a content label when starting a new topic in the Discussions area. Read more to find out why.
robot
List Input into Bivariate Platform
I would like to script a bivariate analysis where the number of Y inputs is unknown.  The Y inputs will vary based on the parent data table, and the number of inputs will change, but their locations will be the same (new columns are added to the end).  How can I script this?  I am using JMP10.
An example is below.
Thanks!
bigClass = Open( "$SAMPLE_DATA/Big Class.JMP" );
cc = bigClass << Get Column Names;
Remove From( cc, 1, 3 );
biv = bigClass << Bivariate( Y( Eval List( cc ) ), X( :age ) ); // How to evaluate cc as data columns?
mpb
Super User mpb
Re: List Input into Bivariate Platform
Try:  Y( Eval(cc) )
mpb
Super User mpb
Try:  Y( Eval(cc) )
robot
Thanks!
