shaira
Link Stack Table with Source Table
I would like to know if there is a way to link Stacked Data Table with its Source Data Table.
The idea is they have a "linked column", e.g. Part ID such that
  1. If I highlight a specific part ID in stack table, it will be highlighted in the source table and vice-versa.
  2. If I exclude specific part ID in stack table, it will be highlighted in the source table and vice-versa.
Thanks,
Shaira
Re: Link Stack Table with Source Table
I am not aware of any automated link that is available, however, you could apply a Row State Handler on the stacked data table, that would take in whatever row in the stacked table has been selected, and then within the handler, one would determine what rows in the original table, and then programmatically select specific rows in the original table.
See
Help==>Scripting Index==>Make Rowstate handler
shaira
Thanks Jim! I'll try this.
