BookmarkSubscribeRSS Feed
jcraine
Community Member
Jan 9, 2013
Levels of gray in principal component tables
In JMP 9, for both the PCA eigenvectors and rotated factor loadings, JMP displays coefficients in different levels of gray.
What are the criteria used to set these levels?
Presumably, they are "strength" or "level of significance", but other than that it's opaque.
