mochar
Occasional Contributor
Legend not showing up saved PNG
dt = Open( "\\someFile.jmp", invisible);
path = "\\path\to\folder\";
names = { "Amplitude 1/2 Vppse", "Amplitude Vppde"};
ngraphs = N Items( names );
For( ip = 1, ip <= ngraphs, ip++,
	current_graph = dt << Variability Chart(
		invisible,
		Y( Column(dt, names[ip])),
		X( :Temp, :vccl),
		Std Dev Chart( 0 ),
			Dispatch(
				{"Variability Chart for " || names[ip]},
				"2",
				ScaleBox,
				{Label Row( {Show Major Grid( 1 ), Show Minor Grid( 1 )} )}
			Dispatch(
				"Variability Chart",
				FrameBox,
				{Row Legend(
					Serial,
					Color( 1 ),
					Color Theme( "JMP Default" ),
					Marker( 1 ),
					Marker Theme( "Standard" ),
					Continuous Scale( 0 ),
					Reverse Scale( 0 ),
					Excluded Rows( 0 )
	current_graph rep = current_graph << Report;
	chart_type = Char(current_graph << Title);
 	chart_type = Munger(chart_type, 1, "[]", "");
 	If(chart_type == "Variability Chart", name = current_graph rep[TextEditBox(1)] << Get Text );
 	name = Munger(name,1,"/", "_");
	final_name = chart_type || "_" || name ;
	picture_path = path || Char(final_name) || ".png";
	current_graph << Save Picture( picture_path, "png" );
Help! So I have managed to make a for loop to make a graph for each column that I put in my array. This actually works :)
BUT, it looks like the legend does not show up even though I have it in the script.
I also notice that in a blank jmp file that just has data and no scripts that run, my data points are just black dots instead of the colored markers I have specified in my script. Is this connected? Do I have to run a script in the data set, and then run the whole .jsl script like the one above after? Why isn't my legend showing up the way I have it specified in my script.
Re: Legend not showing up saved PNG
I should have said that you can avoid both SendToReport and Dispatch.  Each Dispatch command essentially identifies a display box and sends it a message.  After the platform launches, your two commands would become:
current_graph rep[Scale Box(2)] << Label Row(...);
current_graph rep[Frame Box(1)] << Row Legend(...);
A similar script worked for me with sample data.  Are you trying to color by the "Serial" column, or by the measurement column?
mochar
by the serial. I have multiple parts that had several tests run on them. I want to see the serial number in a color and marker as shown in my script. I'll add a picture to my original post to show the results
Ok, it appears that the issue when doing this within a loop is that the Dispatch() statement cannot take an expression like ("Variability Chart for " || names[ip]).  I think you will be better off not using SendToReport and instead add:
mochar
How exactly would I do that when I have two Dispatch inside of the SendToReport? Or do I do it twice like the code below?
			Dispatch(
				"2",
				ScaleBox,
current_graph rep[Frame Box(1)] << Dispatch( {"Variability Chart for " || names[ip]}, "Variability Chart", FrameBox, {Row Legend( Serial, Color( 1 ), Color Theme( "JMP Default" ), Marker( 1 ), Marker Theme( "Standard" ), Continuous Scale( 0 ), Reverse Scale( 0 ), Excluded Rows( 0 ) )} );
mochar
Thanks! At first it wasn't working, but I added
before the Frame Box and Scale Box, and it seemed to do the trick. Thank you!!!!!!!!
