andrewtkarl
Launch Sample Size and Power platform with JSL?
Is it possible to launch the Sample Size and Power platform via JSL? I have not found any referenece to it in the documentation.
ron_horne
Re: Launch Sample Size and Power platform with JSL?
Hi @andrewtkarl
please try the following:
New Window("Sample Size and Power", Sample Size()) ;
it is not clear where this is documented. the way to get it is to open a new session, open the platform you want (sample size) and then save session scrip:
file >>> save session script...
ron_horne
Hi @andrewtkarl
andrewtkarl
Great work! Thank you for your help.
