Hi all,
I would like to launch a PL/SQL (stored in Oracle database) procedure into JMP 7.02.
Through menu File -> Database -> OpenTable and in Advanced button, I select the procedure and give all parameters in the SQL window but when I clic on Execute SQL button, it fails.
Below the SQL construct automaticaly by JMP
EXECUTE CREATETABLE('MYTABLE')
Note : this PL/SQL procedure create a table named mytable.
Thanks for your help
Regards.
