ivanchng
Community Member
Nov 10, 2014
Launch JMP.Application not working for JMP 11
Hi there,
I tried to launch Jmp using my VBA code below but it doesn't popup?
I want to launch the JMP application but failed.
I am using JMP PRO 11 with Wins7 64Bit.
Please advise.
Sub JMP_Test()
    Dim myJMP As JMP.Application
       Set myJMP = CreateObject("JMP.Application")
       myJMP.Visible = True
       DocOpen = True
       Set JMPDoc = MyJMP.OpenDocument("C:\Program Files\SAS\JMP\<versionnumber>\Samples\Data\Big Class.jmp")
       DocOpen = True
End Sub
1 REPLY
briancorcoran
Jun 23, 2011
Re: Launch JMP.Application not working for JMP 11
Before you can automate JMP, you must establish a reference to it.  If you are using Excel and have the "Developer" menu enabled, you need to go to Tools->References.  Within the dialog that comes up, you can select "JMP".  The pane below the selection list should have the Location: C:\Program Files\SAS\JMPPRO\11\jmp.tlb.  Once you do this, then you can start JMP up in VBA code.  If you have already done this, make sure the path to your Big Class file is correct.  For instance, if you are using JMPPro, it will be  c:\program files\sas\jmppro\11\samples\data.  Note the JMPPRO in the directory, not JMP (and a real version #).
Brian Corcoran
JMP Development
