Ransuari
Keeping cell color when split tabels
I used example Sample 49836 to color cells in one column by the value in a different column, but now i need to split the table and keep the cell colors.
I saw a previous discussion regarding concatenated table, with some work around how to get the colors again.
Is there a similar way to do it with split table?
Thanks
Re: Keeping cell color when split tabels
Here is an extension of the sample you referenced that might give you some hint on how to transfer the colors
/* Open a sample data table */
/* Obtain a list of unique values of age */
Summarize( a = By( :age ) );
/* Assign rowstate colors by the values in the age column */
dt << Color by Column( :age, Color Theme( "JMP Dark" ) );
/* Loop through each unique age and assign the rowstate color to the Color Cells */
For( i = 1, i <= N Items( a ), i++,
	r = As List( dt << Get Rows Where( :age == Num( a[i] ) ) );
	Column( dt, "height" ) << Color Cells( Color Of( Row State( r[1] ) ), r );
dtSplit = dt << Split( Split By( :age ), Split( :height ), Remaining Columns( Drop All ), Sort by Column Property );
// loop across all of the columns, and color the non missing cells with the
// color they had in the original data table
For( i = 1, i <= N Cols( dtSplit ), i++,
	// Create a row list from the original table, based upon the column name
	// in the split data table
	r = As List( dt << Get Rows Where( :age == Num( Column( dtSplit, i ) << get name ) ) );
	// Create a list of non missing rows in the split data table
	r1 = As List( dtSplit << Get Rows Where( Is Missing( Column( dtSplit, i )[Row()] ) == 0 ) );
	// Point back to the original data table and get the color from the row state
	Current Data Table( dt );
	TheColor = Color Of( Row State( r[1] ) );
	// Point to the split table, and set the color of all of the
	// non missing cells to the color found in the original table
	Current Data Table( dtSplit );
	Column( dtSplit, i ) << Color Cells( TheColor, r1 );
7 REPLIES 7
Please excuse my ignorance, but where can I find  "Sample 49836 to color cells in one column by the value in a different column".
There is not a direct way to keep the cell colors, but if I can see the specifics of the sample you are referencing, I may be able to fashion a solution.
Jeff_Perkinson
I think the OP is referring to this support note.
-Jeff
Ransuari
This is the one, I'm sorry i haven't put the link on my first post.
after the split I get many continuous columns without any color.
The strange thing I noticed is when I split colored Character column, I do get colors but not the correct ones..
If the colors where correct, I could have change the column to Charecter, split and then change back to Continues, but anyway it's not an elegant solution.
Thanks Again
Ransuari
Thanks for the quick response,
The problem is that I need to split the table by other column then the column used for setting the color by.
in our example, I need to split the table by :sex while the color is defined by :age.
dtSplit = dt << Split( Split By( :sex ), Split( :height ), Remaining Columns( Drop All ), Sort by Column Property );
Thanks Again,
Ran
I was aware that you had not given the precise information on what your split is.  My intension of providing the example I generated, was to give to you an example of the general approach that would have to be taken to solve the issue.  I assume that you should be able to take the example I gave and expand and change it to meet your precise specifications.
Ransuari
Thanks again for your help, I'll use your example and adjust the code accordingly.
