msharp
Keeping a Button at the Top (or Left)
Hey guys, I have a display window where I want to keep a "Run" button at the top.  The display can be several screen sizes in length, but I want the run button to stay at the top so a user can easily access key buttons no matter how far they have scrolled.
I have considered using a Scroll Box(), but having a window that scrolls and a box that scrolls can always be user un-friendly.   I think a VSheetBox might also do the trick, but haven't had a chance to look into it.  Any tips or other suggestions on how to accomplish this?
7 REPLIES 7
Re: Keeping a Button at the Top (or Left)
I would suggest using a border box.  This script has the sides of the border box displayed, so you can see it in relationship to the button box, but they can be turned off.
New Window( "test",
                Button Box( "at top" ),
                Border Box( top( 10 ), Left( 10 ), Right( 10 ), bottom( 10 ), sides( 15 ),
                                V List Box( Spacer Box( size( 1, 30 ) ), Text Box( "text" ), Spacer Box( size( 1, 30 ) ), Text Box( "second text" ) )
msharp
This doesn't appear to be a solution, adding some more text boxes, collapsing the window and scrolling down, shows that indeed, the button doesn't stay at the top.  It needs to stay at the top ALWAYS.  Meaning, it needs to always be displayed.
As you can see, I can manipulate the window in such a way that the button isn't displayed.
Your observation is correct.......You can change the border box to a scroll box, but that will have an issue too, once the window size is smaller than the scroll box.
pmroz
FWIW this will scroll and leave the button at the top, but requires the use of a tablebox.  If you figure out how to do it for things other than a tablebox please share!
New Window( "Example", button box("Test Button"),
tbox = Data Table Box( dt ) );
tbox << set scrollable(10, 0);
ian_jmp
Not a button as such, but here's a plausible alternative:
Outline Box( "Commands",
{"Action 1", Beep(), "Action 2", Beep();Wait(0.1);Beep()},
V List Box(
Text Box( "text" ),
Text Box( "second text" ),
Text Box( "text" ),
Text Box( "text" ),
pmroz
I found  v scroll box  which for some reason is not in the scripting index under display boxes.  It's under functions
      v scroll box(size(100), flexible(1),
            vlistbox(
                  textbox("First long text"),
                  textbox("Second"),
                  textbox("Third"),
                  textbox("Fourth"),
                  textbox("Fifth"),
                  textbox("Sixth"),
                  textbox("Seventh"),
                  textbox("Eigth"),
                  textbox("Ninth"),
                  textbox("Tenth"),
                  button box("Bottom")
msharp
Thanks guys, reading your thoughts helped get me on the right track.  I ended up combining a vsheetbox and vscrollbox.  In unison you get a clean interface that overcomes the deficiencies in using just one or the other.
      v sheet box(
            scrollbox(flexible(1),
                           vlistbox(
                  textbox("Second"),
                  textbox("Third"),
                  textbox("Fourth"),
                  textbox("Fifth"),
                  textbox("Sixth"),
                  textbox("Seventh"),
                  textbox("Eigth"),
                  textbox("Ninth"),
                  textbox("Tenth"),
