Journal outline items - add image
How do I add a graphic (eg. an image of a ppt slide) to a journal under a specific outline item?
I can only seem to add images to the end of the journal whereas I would like to be able to add them in an outline section so that they are only seen when a section is opened.
Thanks
Chemist
Re: Journal outline items - add image
Problem solved. Do it in JMP8 not JMP9..
