Rajat
Join two tables by matching common column name
I have two tables as below.
Table1 :
NameSectionSubject
AdamAMath
BobAscience
ChrisBenglish
Table2:
NameSectionScore
AdamA80
BobA90
ChrisB84
I want to join both table in jsl and get the following output table but I don't want to give matching column names explicitly. Matching columns would be the columns with same column name in both table. Matching columns can vary. It can be 2 (as in shown example) or 3 or more but matching column would have same column name.
output:
NameSectionSubjectScore
AdamAMath80
BobAscience90
ChrisBenglish84
david707
Re: Join two tables by matching common column name
This should do it:
DT1 = New Table("DT1",
	<< Add Rows(3),
	<< New Column("Name", character, Values({"Adam","Bob","Chris"})),
	<< New Column("Section", character, Values({"A","A","B"})),
	<< New Column("Subject", character, Values({"Math","Science","English"}))
DT2 = New Table("DT2",
	<< Add Rows(3),
	<< New Column("Score", numeric,continous, Values({80,90,84}))
LSTcols1 = DT1 << Get Column Names(string);
LSTcols2 = DT2 << Get Column Names(string);
STRjoinCols = "";
For(LVC=1,LVC<=N Items(LSTcols1),LVC++,
	STRcol = LSTcols1[LVC];
	If(
		Contains(LSTCols2,STRcol)
		If(
			STRjoinCols == ""
			STRjoinCols = ":"||STRcol||"==:"||STRcol
			STRjoinCols = STRjoinCols||", :"||STRcol||"==:"||STRcol
expr = Eval Insert(
	DT3 = DT1 << Join(
				With( DT2 ),
				Merge Same Name Columns,
				Match Flag( 0 ),
				By Matching Columns( ^STRjoinCols^ ),
				Drop multiples( 0, 0 ),
				Include Nonmatches( 0, 0 ),
				Preserve main table order( 0 ),
				Output Table( "DT3" )
Eval( Parse( expr ) );
david707
This should do it:
	<< Add Rows(3),
	<< Add Rows(3),
STRjoinCols = "";
	If(
		If(
			STRjoinCols == ""
expr = Eval Insert(
	DT3 = DT1 << Join(
				With( DT2 ),
				Match Flag( 0 ),
