Filipbombeke
Join tables
I want to join to two tables by matching columns (timestamp) with include non-matches for the onepager_HPPO table. The data from second table onepager HPPO_adddata_ONSTS is only present until 08/08/08 10:00 in the joined tables although it should be until end of 2019. The format of two timestamps is identical. What cause this issue or how can it be resolved?
Re: Join tables
The issue is, that in data table ONEPAGER HIPPO_adddata_ONSTS, on 08/08/2018 at 11AM the input data changes.  At 10AM the value is
08/08/2018 10:00:00.000 AM
at 11AM it changes to
08/08/2018 10:59:59.999 AM
If you run a little script that rounds all of the values to whole numbers, and then join the data, that should fix the issue.
Thierry_S
Re: Join tables
Hi Filip,
It looks like there might be a bug: I did reproduce your problem even when I forced the date stamp to be in numerical format. The only work around I could find, which is rather ugly, is to extract the HOUR, DAY, MONTH, and YEAR in separate columns for each table and joined based on all 4 values.
Maybe somebody else will have more insight.
Best,
TS
Thierry R. Sornasse
Re: Join tables
Filipbombeke
Re: Join tables
Indeed - I did not noticed this. Rounding the timestamps solved the issue. Thanks!
Article Labels
