Jmp script to get variability charts with common x-grouping
I am a bit new to jmp, so bare with me. I was looking to graph variability plots that plot the same y-variable and same x-grouping but separated by different variables in the 'By' section. For example, how do I get the plot that looks like the one on the left and not the one on the right (that it produces by default). Is there a JSL script to do such a thing?
Re: Jmp script to get variability charts with common x-grouping
I don't think you need a script to get something close to what you want. I mocked up a dataset to mimic your scenario. The X-axis variables are called Level 1, Level 2, and Level 3. The response variable I called Response. The By variable I called Grouping. I have attached the table to this post.
Since you are looking for a graph, I went to Graph > Graph Builder.
Drag Response to the Y-axis.
Drag Level 1 to the X-axis.
Drag Level 2 to the X-axis so that it is just "inside" the x-axis border. You will see the graph update to show the nesting of the two variables.
Repeat this process for Level 3.
Now drag the ByVar over to the Grouping area.
That should give you a plot with all of the points.
Dan Obermiller
