radhi
Jmp diagram save
Hello
When I have saved a diagram and I want to open it I don't find the saved diagram as I keep it last time.
Thank you
celestine
Re: Jmp diagram save
it would be great if you can provide some code. else, i would recommend you to check the directory you saved in. also, assuming you are saving a diagram from a report, make sure you get the parent branch right, else it won't save properly.
