BookmarkSubscribeRSS Feed
ravi_jmp
Nov 3, 2011
Jmp Script Problem
I am running the following JMP script, joining some files and creating new columns, towards building a combined final report. When I run this script, the last line generates the 'Temp1' table, with all the column names, but no data. If I break the script before this line and run the script from the last line onwards separately, it works fine. Wondering if any one could tell me why I am having to break the script into two.
Thanks,
Ravi
Data Table( "File1" ) << Join(With( Data Table( "File7" )), Merge Same Name Columns, By Matching Columns( :Die = :Die ), Output Table( "FileA" ));
New Column("Die_loc", Character, Nominal, Formula(Substr(:Die, 14, 7)));
Data Table( "File2" ) << Join(With( Data Table( "File8" )), Merge Same Name Columns, By Matching Columns( :Die = :Die ), Output Table( "FileB" ));
Data Table( "File3" ) << Join(With( Data Table( "File9" )), Merge Same Name Columns, By Matching Columns( :Die = :Die ), Output Table( "FileC" ));
Data Table( "FileA" ) << Join(With( Data Table( "FileB" )), Merge Same Name Columns, By Matching Columns( :Die_loc = :Die_loc ), Output Table( "Temp1" ));
ms
Jun 23, 2011
Solution
Jmp Script Problem
One possibility is that the evaluation of formulas in the new columns has not finished before the final Join(). Try if inserting Eval Formula in each New Column() helps.
New Column("Die_loc", Character, Nominal, Formula(Substr(:Die, 14, 7)), Eval Formula);
6 REPLIES 6
ms
Jun 23, 2011
Solution
Jmp Script Problem
pmroz
Jun 23, 2011
Jmp Script Problem
You can also force some buffers to be flushed with the wait command:
wait(0);
ravi_jmp
Nov 3, 2011
Jmp Script Problem
PMroz, your suggestion works too. Thanks
ravi_jmp
Nov 3, 2011
Jmp Script Problem
Thanks for the suggestion MS, that worked.
David_Burnham
Jul 13, 2011
Jmp Script Problem
Send the message Run Formulas to the data table.  This message completes all formula evaluations before proceeding to the next JSL statement.
-Dave
GoodMan
Oct 28, 2011
Jmp Script Problem
Hi Ravi, Can you let me know the function of the following JSL in your code. Thanks,Kun.
