JSON import from URL: misaligned output table
Hi all,
I'm trying to import data from an URL which return json data. Example json data looks like this:
{"csvrow": ["237", "623", "1967"], "name": ["A_N10_C010_R196", "A_N10_C270_R092", "A_G12_C220_R189"], "optRs": ["0.0", "0.0", "0.0"]}
Following the approach discussed here How to parse a JSON file opened from URL?
I'm using a simple script command:
open([URL], JSON)
Otherwise it works fine, but the output table is misaligned (cannot a attach a screenshot here but maybe this tells the strory):
  csvrow name optRs
1 237
2 623
3 1967
4   A_N10_C010_R196
5   A_N10_C270_R092
6   A_G12_C220_R189
7     0
8     0
9     0
Should I pass some parameters to the open command to get a table of only 3 rows, values in each cell? Like this:
  csvrow name optRs
1 237 A_N10_C010_R196 0
2 623 A_N10_C270_R092 0
3 1967 A_G12_C220_R189 0
The documentation looked somewhat thin on this.
Thanks for help!
Craige_Hales
Staff (Retired)
Re: JSON import from URL: misaligned output table
JMP 15 has a JSON wizard that will do better.
JSON wizardJSON wizard
You can also use File->Open and pick the json filter and ask for the wizard
Pick the json filter and ask for the preview wizardPick the json filter and ask for the preview wizard
Grab the table's source script to repeat it later without the wizard.
Craige
Craige_Hales
Staff (Retired)
Craige
Thanks - this is exactly what I was looking for!
