BookmarkSubscribeRSS Feed
Thomas1
JSL to select a column for a formula script
What JSL code must be added to the formula code:
New Column („Missing“, Numeric, Nominal, Formula (Is Missing : Name("Column 1")))
to get an dialog with which it is possible to select all columns of a data table?
uday_guntupalli
Re: JSL to select a column for a formla script
@Thomas1,
      Please look at Column Dialog()
Best
Uday
Thomas1
Thanks for your hint Uday.
Now I'm able to start the dialog and to select a column. However I can't pass the selected column properly to the formula, in order to create the new column with the formula being applied.
uday_guntupalli
@Thomas1,
       You can use the dialog() function to further offer customization. However, if it is not required that the user needs to make a selection, that would be much easier. I would use the examples in Scripting Index for Dialog(), I personally haven't used it much so cannot provide a ready example
Best
Uday
