BookmarkSubscribe
djhanson
JSL to Disable an Add-In?
Hi All, does anyone know if JSL can disable a JMP Add-In (knowing its Add-In name of course)?  If so, can you post some example code?
In other words, I'm looking for JSL to effectively uncheck "Enabled" from the Views > Add-Ins > Add-In Status window.  thanks, DJ
djhanson
Re: JSL to Disable an Add-In?
ok, I discovered something that might work for my needs: Unregister AddIn();
This command wasn't listed in the Scripting Guide, I just discovered it by placing "Un" in front of Register AddIn();
DJ
Kevin_Anderson
Hi, DJ!
It's in the Scripting Index too.
For those of us who are less scripting inclined you can also go to View > Addins  and click the Unregister button there.
