My solution to this is to put important commas at the level of the enclosing fence.  Here is an example -- notice that the commas separating the IF blocks are at the level of the IF statement, and the same for TRY
Names Default to Here( 1 );
Try(
	If( Contains( dt << Get Column Names, As Name( "height" ) ),
		mean = Col Mean( dt:height );
		max = Col Max( dt:height );
		min = Col Min( dt:height );
		std dev = Col Std Dev( dt:height );
		Write( "\!NSome stats on :HEIGHT:",
			"\!NMin: ", min,
			"\!NMax: ", max,
			"\!NMean: ", mean,
			"\!NStd Dev: ", std dev
		Contains( dt << Get Column Names, As Name( "weight" ) ),
		mean = Col Mean( dt:weight );
		max = Col Max( dt:weight );
		min = Col Min( dt:weight );
		std dev = Col Std Dev( dt:weight );
		Write( "\!NSome stats on :WEIGHT:",
			"\!NMin: ", min,
			"\!NMax: ", max,
			"\!NMean: ", mean,
		Contains( dt << Get Column Names, As Name( "age" ) ),
		mean = Col Mean( dt:age );
		max = Col Max( dt:age );
		min = Col Min( dt:age );
		std dev = Col Std Dev( dt:age );
		Write( "\!NSome stats on :AGE:",
			"\!NMin: ", min,
			"\!NMax: ", max,
			"\!NMean: ", mean,
		Print( "Cannot find columns 'height', 'weight', or 'age'" )
	Print( "mistakes were made" )
	Jordan
