ghartel
JSL: how can you script make a validation column using stratified random
I want to create a validation column using stratified random in JSL, but it doesn't seem to let me incldue the column name for stratification:
Make Validation Column(
	Training Set( 0.50 ),
	Validation Set( 0.25 ),
	Test Set( 0.25 ),
	Stratified Random(:Group)
this brings up a column selection dialog.  I cant find documentation how to specify the column in JSL code.
Re: JSL: how can you script make a validation column using stratified random
I played around with the Make Validation Column object, and as you indicated, I could not make the Stratified Random work without having the column selection window come up.  However, I was able to add a By() element into the script and it may work for what you want:
dt << Make Validation Column(
	Test Set( 0.25 ),
	formula random,
	by( :group )
	Test Set( 0.25 ),
	formula random,
	by( :group )
aronwilson
This worked great by the way. I was able to use this in a script to quickly general validation columns stratified by another column.
Article Labels
