BookmarkSubscribeRSS Feed
uwe_hiss
Aug 12, 2015
JSL: how can I get a "pathfinder"?
with following script I would like  to create a "pathfinder" with variables (choosen items from List Box).
What am I doing wrong?
spath = "R:\00 DnA\2015\";
// or npath = "nasdlkxxx\AB1_FileShare06\wpa001\00 DnA\2015\"
Tpm = {
  Famar,
  Gnosis,
  Hospira,
  LabBio
FamarSUB = {
  Brufen P278,
  Brufen P280,
  Brufen N950,
  Clari 3368,
  Clari 10061,
  Clari G656,
  Clari L214,
  Clari L950,
  SAMe N309 G,
  SAMe N309 TB,
  SAMe N917 G
GnosisSUB = {
  SAMe 16373 S4,
  SAMe 24358 S7,
  SAMe 53570 S21
HospiraSUB = {
  SAMe N309,
  SAMe N917,
  SAMe P332
LabBioSUB = {
  SAMe N309 G,
  SAMe N309 TB,
  SAMe N917 G
tpar = Associative Array( Tpm, {FamarSUB, GnosisSUB, HospiraSUB, LabBioSUB} );
New Window( "Select TPM AND Product", << Modal,
     V List Box(
           Text Box( "Select TPM" ),
           tpmbox = List Box(Tpm,
  prodbox << remove all;
  prodbox << append(
                            Eval ( tpar[Parse( (tpmbox << get selected)[1] )] ));
                            ctpm = tpmbox << get selected;
           Text Box( "Select Product"),
           prodbox = List Box ({}),
           Button Box( "OK", cpro = prodbox << get selected ),
data_path = spath||ctpm||"\"||cpro||"\Database";
data_file= Pick File("Select data base");
dt_data= Open(data_path||data_file, invisible);
spec_path = spath||ctpm||"\"||cpro||"\Misc\Specs";
spec_file= Pick File("Select spec file");
dt_spec= Open(spec_path||spec_file, invisible);
Thank you in advance,
Uwe
David_Burnham
Jul 13, 2011
Solution
Re: JSL: how can I get a "pathfinder"?
The selected items from a list box form a list - even if there is only one selection.  So in your code "ctpm" and "cpro" are lists and so the string concatenation fails when you construct the data_path variable.  You need something like:
selectedTpm = ctpm[1];
selectedPro = cpro[1];
data_path = spath || selectedTpm || "\" || selectedPro || "\Database";
and
spec_path = spath || selectedTpm || "\" || selectedPro ||"\Misc\Specs";
-Dave
David_Burnham
Jul 13, 2011
Solution
and
-Dave
