Thierry_S
JSL > Preserving Default Entries for Text Edit Box: Code Improvement
Hi JMP Community,
I have been toying with a short script to group column automatically based on a starting and ending string.While this work fine on my local machine, I would like to know if there is a better way to preserve default entries for the Text Edit Boxes from run to run than holding those default entries in a separate file?
Here is my code so far: Any suggestion on improving any part of it?
Names Default to Here (1);
dt = Current Data Table ();
CList = dt << get column names (string);
GList = {};
NCol = N Items (CList);
Try (dat = open("C:\AUTODAT.JMP", Invisible),
		dat = new table ("AUTODAT", Invisible,
							Add Rows (2),
							New Column ("Entries", Character, Nominal, set values ({"NEW START", "NEW END"}))
DefStart = column (dat, "Entries") [1];
DefEnd = column (dat, "Entries") [2];
Dlg = New Window (" AUTO-GROUPING: ENTER SEARCH STRINGS",
	<< Modal,
	Border Box (top (15), Bottom (15), Left (40), Right (40),
		V List Box (
			Text Box ("ENTER START STRING:"),
			ST = Text Edit Box (DefStart, Set Width (200)),
			Spacer Box (0,25),
			Text Box ("ENTER END STRING:"),
			ET = Text Edit Box (DefEnd, Set Width (200)),
			Spacer Box (0,25),
			Button Box ("OK",
				StartString = ST << Get Text ();
				EndString = ET << Get Text ()
			Button Box ("CANCEL",
				Close( dat, NoSave );
				Throw (1))
Column (dat, "Entries")  << set values (Eval List ({StartString, EndString}));
dat << Save As ("C:\AUTODAT.JMP", 1);
Close (dat, NoSave);
Switch = ((Length (StartString) > 0) * 10) + (Length (EndString) > 0);
For (i = 1, i <= NCol, i++,
	Match (Switch,
			11,
			if(Starts With (CList [i], StartString) & Ends With (CList [i], EndString),
				Insert into (GList, CList [i])),
			10,
			if(Starts With (CList [i], StartString),
			1,
			if(Ends With (CList [i], EndString),
			0, Throw (1)
Group = dt << Group Columns (GList);
Thierry R. Sornasse
Re: JSL > Preserving Default Entries for Text Edit Box: Code Improvement
My standard way of handling what you are doing with a saved data table, is to save the values I need to save, as JSL.  I just create a text string with the required JSL to initialize the values and save it using Save Text File().  Then on subsequent runs, I just use an Include() to initialize the values.
Thierry_S
Hi Jim,
Always on top of things and right on the money.
Thanks,
TS
Thierry R. Sornasse
