BookmarkSubscribeRSS Feed
janeg
Aug 14, 2012
JSL from dos prompt - just display table and not main window?
Hi Folks,
I want to launch JMP with a given jsl script.  Within that jsl script is a command to open a jmp table.    Simple enough.
However, when I do this - the main JMP window also opens.   I don't want the main window to open.
I just want the table displayed.
And when the user saves and closes the table, I'd like JMP to exit.
Is there a way to do this either via the command line options or in the jsl script?
I am using JMP 10.
Jane
Dos command:
cmd /c start /wait jmp  -NoTip -NoSession -NoSplash "C:\exper.jsl"
JSL script  C:\exper.jsl contains
Open("C:\testopen.jmp");
janeg
Aug 14, 2012
Solution
Re: JSL from dos prompt - just display table and not main window?
For anyone who has the same question in the future,  I have submitted to the JMP File Exchange an example of the solution to accomplish this task.
The title of which is Example: cmd line launch, table edit/close notify
Hope it proves useful to someone in the future.
Jane
janeg
Aug 14, 2012
Solution
Jane
