yu629xiao
JSL for Loop question
While using two Loop in same JSL script like below, One is to draw Bivariate chart by different "ToGraphBy" another one is to add Spline for those charts with different Color (by "Flag") . however, as second Loop counts "Flag"  from all table  instead of each separated segment by "ToGraphBy" , that cause each segment charts points color mismatch with Spline color. Who can help us to modify this script a little big to make it more reasonable ?
dt = Current Data Table();
Summarize( dt, byVals = by( :TOGRAPHBY ) );
Summarize( dt, ByFlag = by(:Flag ) );
Bi = Bivariate( X( :LOT_DATA_COLLECT_DATE ), Y( :CHART_VALUE ), by( :TOGRAPHBY ));
For( i = 1, i <= N Items( byVals ), i++,
LCL = :LO_CONTROL_LMT[(dt << get rows where( :TOGRAPHBY == byVals[i] ))[1]];
UCL = :UP_CONTROL_LMT[(dt << get rows where( :TOGRAPHBY == byVals[i] ))[1]];
TGT = :TARGET[(dt << get rows where( :TOGRAPHBY == byVals[i] ))[1]];
chartMin = Min( :CHART_VALUE[dt << get rows where( :TOGRAPHBY == byVals[i])]);
chartMax = Max( :CHART_VALUE[dt << get rows where( :TOGRAPHBY == byVals[i])]);
If(LCL < chartMin, chartMin = LCL );
If(UCL > chartMax, chartMax = UCL );
chartRange5% = (chartMax - ChartMin)/5;
Gridset=(UCL - LCL)/5;
chartMin = chartMin - chartRange5%;
chartMax = chartMax + chartRange5%;
Eval(
Substitute(
Expr(
Bi << SendToByGroup(
{:TOGRAPHBY == __byVals__},
Dispatch(
"1",
ScaleBox,
{Format( "y/m/d h:m:s", 22, 0 ), Min(),
Max( ), Interval( "Day" ), Inc( 1 ), Minor Ticks( 0 ),
Label Row( Label Orientation( "Vertical" ) )}
Dispatch(
"2",
ScaleBox,
{Min( __min__ ), Max( __max__ ), Inc( __Grid__ ), Minor Ticks( 1 ), Label Row( Show Major Grid( 1 )),
Add Ref Line( __LCL__, "Solid", "Medium Dark Red", "LCL", 1 ),
Add Ref Line( __TAR__, "Solid", "Blue", "Target", 2 ),
Add Ref Line( __UCL__, "Solid", "Medium Dark Red", "UCL", 1 )}
Dispatch(
"Bivar Plot",
FrameBox,
{Frame Size( 900, 600 ),Marker size (2), Row Legend(
Flag,
Color( 1 ),
Color Theme( "JMP Default" ),
Marker( 1 ),
Marker Theme( "Standard" ),
Continuous Scale( 0 ),
Reverse Scale( 0 ),
Excluded Rows( 0 )
Expr( __byVals__ ), byVals[i],
Expr( __UCL__ ), UCL,
Expr( __LCL__ ), LCL,
Expr( __min__ ), chartMin,
Expr( __max__ ), chartMax,
Expr( __Grid__ ), Gridset,
Expr( __TAR__ ), TGT
For( i = 1, i <= N Items( ByFlag ), i++,
bi << Fit Where(
:Flag == ByFlag[i],
Fit Spline( 1e16)
Byron_JMP
Re: JSL for Loop question
this is a pretty phenomenal complex bit of script.
are you sure you can't just make a summarized table and plot from there.
in CCB you can load limits from a table. If you need to you could make a summary table and then also make a table of limits. Plot from one, and get limits from the other, maybe?
JMP Systems Engineer, Pharm and BioPharm Sciences
