shilpa
JSL error not enough arguments in access or evaluation of 'For'
I am beginner in JSL scripting. I need help with the following error.
"not enough arguments in access or evaluation of 'For' "
In my code below, I am trying to delete columns that contain certain strings in their column name. I'm not sure where I am making the mistake.
dt = Current Data Table();
col_list = dt << get column names(string);
for(i = 1; i>= N Items (col_list), i++,
If(
Contains(col_list[i], "MTR") | Contains(col_list[i], "AUTO") | Contains(col_list[i], "ProcessCon") | Contains(col_list[i], "Macro") | Contains(col_list[i], "OTH_SP") ),
Remove from(col_list, i)
dt << delete columns( col_list );
Please let me know. Thank you.
Jeff_Perkinson
Re: JSL error not enough arguments in access or evaluation of 'For'
You've got a semi-colon (;) after the first argument instead of a comma (,).
You've also got an extra close parentheses.
It should be:
col_list = dt << get column names( string );
For( i = 1, i >= N Items( col_list ), i++,
//________^
//comma here, no semi-colon
	If(
		Contains( col_list[i], "MTR" ) | Contains( col_list[i], "AUTO" ) |
		Contains( col_list[i], "ProcessCon" ) | Contains( col_list[i], "Macro" ) |
		Contains( col_list[i], "OTH_SP" )
	Remove From( col_list, i )
//don't need close parentheses above
-Jeff
Jeff_Perkinson
It should be:
//________^
	If(
-Jeff
shilpa
Hi Jeff,
Thank you. That got rid of the error. However, I must have made a logical error. The code I had, erased all the columns in the data table.
Perhaps, I'm making a mistake with delete columns?
Instead of "Remove from (col_list, i)", am I allowed to write the following?
dt<< delete columns(col_list[i]); ?
I'm not sure of the syntax. But my aim is to delete all columns which has "MTR" or "ProcessCon" etc in their column name.
Please let me know.
shilpa
I was able to get around the issue and below code worked for me to delete columns based on column name.
Clear Log();
col_list = dt << get column names;
For( c = N Cols( dt ), c >= 1, c--,
	If(
		Contains( col_list[c], "MTR" ) | Contains( col_list[c], "AUTO" ) | Contains( col_list[c], "ProcessCon" )
		 | Contains( col_list[c], "Macro" ),
		dt << deleteColumn( c )
