Hi All,
I was wondering if anybody new the JSL code to import a table as datatable I am trying to write a script to read in a table from an SSRS report.
I can open the SSRS report using the web(,JMP Window)function and I can manually import the table I want using file<import table as data table.
When I manually select this JMP then reads the webpage for valid tables and I can import the one I want.
using the open(, HTML Table(n)) function wont work as this is an SSRS page and needs to be scanned each time.
So I need to write a script that will automatically scan the webpage and import the table I m after. I would really appreciate any thoughts on this as all my attempts so far have failed!!
Kind Regards,
Lenny.
