BookmarkSubscribeRSS Feed
fidaleom
Oct 20, 2014
JSL code for model simulation
Hello! I created a model for a system and I am interested in simulating this system by using the developed model through JMP simulator (under the profiler menu). I need the JSL code for this action, that is the code that allows me to simulate the process starting from the independent variables and the prediction formula. I need the simulation to consider also the noise associated to the model. I would appreciate any help on this.issue.
Many thanks,
Marcello.
ian_jmp
Jun 23, 2011
Re: JSL code for model simulation
One of the nice things about JMP is that it generates code for you. So, when in doubt, try doing things 'by hand' and inspect the resulting code (use 'Script > Save Script to Script Window'). Bear in mind that code generated this way tends to be verbose.
NamesDefaultToHere(1);
dt <<
// JMP generated code follows . . .
Fit Model(
  Y( :height ),
  Effects( :weight ),
  Emphasis( "Effect Leverage" ),
  Run(
  Profiler(
  1,
  Confidence Intervals( 1 ),
  height << Response Limits(
  {Lower( 50, 0.066 ), Middle( 61.25, 0.5 ), Upper( 72.5, 0.9819 ),
  Goal( "Maximize" ), Importance( 1 )}
  Term Value( weight( 134.8, Lock( 0 ), Show( 1 ) ) ),
  Simulator(
  1,
  Factors( weight << Random( Normal( 134.8, 9 ) ) ),
  Responses( height << No Noise ),
  Resimulate
  :height << {Plot Actual by Predicted( 1 ), Plot Residual by Predicted( 1 ),
  Plot Effect Leverage( 1 )}
  Dispatch( {"Response height"}, "Whole Model", OutlineBox, {Close( 1 )} ),
  Dispatch( {"Response height"}, "weight", OutlineBox, {Close( 1 )} ),
  Dispatch(
  {"Response height", "Prediction Profiler"},
  "Profile Simulator Histogram",
  FrameBox,
  {DispatchSeg( Hist Seg( 1 ), {Histogram Color( 4 ), Bin Span( 2, 0 )} )}
  Dispatch(
  "Simulator",
  OutlineBox,
  {Close( 1 )}
fidaleom
Oct 20, 2014
Thanks Ian. I had never tried the ‘save script to script window’, I found it useful.
Da: Ian@JMP
Inviato: giovedì 10 settembre 2015 20.41
A: Marcello Fidaleo
Oggetto: Re: - JSL code for model simulation
<https://community.jmp.com/?utm_source=JIVE&utm_medium=email&utm_campaign=System%20Email%20Tracking> JMP User Community
reply from Ian@JMP <https://community.jmp.com/people/Ian%40JMP?et=watches.email.thread> in Discussions - View the full discussion <https://community.jmp.com/message/223276?et=watches.email.thread#223276>
