Stokes
[JSL bug] Concatenate all opened table into 1 table and close all
Can someone help me to take a look bellow jsl?
I am trying to use it concatenate all open table into a single table, and close all the open table, only leave a final table which was concatenated from all of them.
When I run the jsl, it has a bug to re-produce multiple "final" table and not concatenate into 1 single table.
Not clear where the bug is coming from.
Thanks
Clear Globals();
// Create your Tables list
Tables = {};
For( i = 1, i <= N Table(), i++,
    Insert Into( Tables, Data Table( i ) << get name )
// Run the concatinations
For( i = 1, i < N Items( Tables ), i++,
    ConcTable = Data Table( Tables[i] ) << Concatenate(
        Data Table( Tables[i + 1] ),
        Create source column,
        Output Table Name( "final" )
    Close( Data Table( Tables[i] ), No Save );
Re: [JSL bug] Concatenate all opened table into 1 table and close all
Doing what you want to do, if you didn't want the Source Table Column, is very simple
Clear Globals();
Tables = {};
	Insert Into( Tables, Data Table( i ) << get name );
new Table("all data");
For( i = 1, i <= N Items( Tables ), i++,
	 Data Table( "all data" ) << Concatenate(
		append to first table(1)
It gets more complex if you want a Source Table.  Using the built in option of "Create Source Column", will produce a new Source Table column for each concatenation you do.  So some adjustments need to be made.  Below is a working script that should give you what you want
Clear Globals();
Tables = {};
TablesN = {};
	for(k=1,k<=n rows(data table(i)),k++, insert into(TablesN,data table( i ) << get name));
 data table( "all data" ) << add multiple columns("Source Table", 1, before first, character );
:Source Table << set values( TablesN );
Clear Globals();
Tables = {};
Clear Globals();
Tables = {};
TablesN = {};
Stokes
This is great, thanks Jim.
gzmorgan0
@Stokes,
The script you posted is creating  a bunch of new tables.  Community note: I do not know if there is a syntax to close a list of data tabes, hence, the For Loop is used to close the source tables one at a time, by name, not number.
Names Default to Here(1);
//Careful, this closes all data tables
close all(Data Tables);
//now create similar looking tables
dt = Open("$Sample_Data/Big Class.jmp");
dt << Subset( By (:age));
//close Big Class, keep all the age subset tables open
close(dt,NoSave);
nt = N Table();
Tables = {};
For( i = 1, i <= nt, i++,
	Insert Into( Tables, Eval Expr( Data Table( Expr( Data Table( i ) << get name ) ) ) )
final = Concatenate( Tables, Create Source Column, Output Table Name( "Big Class Redux" ) );
//close all in the list
	Eval( Eval Expr( Close( Expr( Tables[i] ), NoSave ) ) )
gzmorgan0
Oops, sorry Jim,  @txnelson , I didn't see your response.
Article Labels
