ileshem
JSL, Using IF formula and Else value
I have a table:
NameScoreReasonScore2
John100Test
Dan95HW
Elli92Sick
I want to add a JSL formula to "Score2" column which takes the value from "Score" unless there is the word "Sick" in the "Reason" column:
NameScoreReasonScore 2
John100Test100
Dan95HW95
Elli92Sick100
Below is what I have but it doesn't perform the Else as I need it to:
dt1 <<new column ("Score2",
	Numeric,
	"Continuous", formula (If( :Reason == "Sick",
	"100",
	:Score
Thank you in advance.
Re: JSL, Using IF formula and Else value
You are creating a numeric column, but you are trying to give it a character string column value of "100".  By placing quotes around the 100, you are telling it to make the value a character string.  Leave the quotes out to assign a numeric value.
dt1 << New Column( "Score2",
	Numeric,
	"Continuous",
	formula( If( :Reason == "Sick", 100, :Score ) )
There is also a possible problem if the column Score is not a numeric column in your data table.  If it is a character column, change your code to:
	Numeric,
	"Continuous",
	formula( If( :Reason == "Sick", 100, num( :Score ) ) )
	Numeric,
	"Continuous",
	Numeric,
	"Continuous",
