gbu
gbu
[JSL] Spec limits and reference lines
Is everybody know how script the "Show as graph reference lines" in column property Spec limits ?
Maybe something to add after target, but nothing found in jsl documentation.
col<<Set Property("Spec Limits", {LSL(-1), USL(1), Target(0)});
Any idea ?
Thanks
Regards,
Guillaume
ms
Super User ms
Try to insert
Show Limits( 1 )
That is the syntax returned by manually setting the property and then running
col << get script
ms
Super User ms
Try to insert
Show Limits( 1 )
col << get script
gbu
gbu
Excellent.
Thanks for your answers and thanks for the tip.
matthewh
Re: [JSL] Spec limits and reference lines
Hi MS,
does this only work in the latest version of JMP? I am still using JMP 8 and the "Show as graph reference lines" option doesn't appear. To get spec lines to appear on a Box Plot (for example), I have resorted to the ugly method of parsing the output of Get Property("spec limits")! I am sure there is a nicer way to do it even in JMP8, can you help me out? It happens automatically in a Distribution plot, but not a box plot or variability chart.
Thanks,
Matthew.
ms
Super User ms
My licence for JMP 8 seems to have expired so unfortunately I can't easily test if and how it could work in that version. However "Show as graph reference lines" is there as an option in both JMP 9 and 10.
Article Labels
