BookmarkSubscribe
carole
JSL - Select Points Inside ellipse
i'd like to use JSL to Select Points Inside a density ellipse. These commands don't work:
biv = Bivariate(
    Y( :YREL ),
    X( :XREL ),
    Density Ellipse( 0.5, {Line Color( {213, 72, 87} )})
repbiv = biv    <<    report;
repbiv["Bivariate Normal Ellipse P=0.500"] << Select Points Inside;
If someone has an idea, thank you for your help...
ms
Super User ms
Try:
biv << (Curve[1] << Select Points inside);
If you have other fitted curves in the same graph you may need to use Curve[2], ocr Curve[3] etc. depending on the order in which they are drawn.
ms
Super User ms
Try:
carole
Thank you very much, it works !
