BookmarkSubscribeRSS Feed
joeldomo
Aug 20, 2014
JSL - Save Best Transformation
I'm running the script below and it will stop after the box-cox outline box generation. What i do is then is to manually 'Save Best Transformation' in the 'Box Cox Transformation' outline box. My question, Is there a way to automate the 'Save Best Transformation' via JSL to continue with the script on more items to transform? thanks to help
-Rgsd, Joel
Clear Log();
dtName = "Big Class";
dt = Open( "$SAMPLE_DATA/" || dtName || ".jmp" );
nwd = New Window( "Box Cox",
dt << Fit Model(
Y( :weight ),
Effects,
Emphasis( "Effect Leverage" ),
Run(
:weight << {Summary of Fit( 1 ), Analysis of Variance( 1 ), Parameter Estimates( 1 ), Lack of Fit( 0 ), Plot Actual by Predicted( 1 ),
Plot Regression( 0 ), Plot Residual by Predicted( 1 ), Plot Effect Leverage( 1 ), Box Cox Y Transformation( 1 ),
save best transformation( 1 )}
stephen_pearson
Oct 6, 2014
Solution
Re: JSL - Save Best Transformation
If you create the code you shared in JSL as a string and have all the column names you wish to transform as a list (colListYBoxCox) then you can substitute in the column names and loop over all the columns in your list (example below).
I have done this and then checked if the box-cox transformation made a big difference, and automatically deleted those which were a waste of time.
Regards,
Stephen
For( i = 1, i <= N Items( colListYBoxCox ), i++,
boxcoxstring = "boxcoxwindow = Fit Model(
Y(";
boxcoxstring = Concat( boxcoxstring, ":Name(\!"", colListYBoxCox[i], "\!")," );
boxcoxstring = Concat( boxcoxstring, ")," );
boxcoxstring,
"Effects,
Personality( \!"Standard Least Squares\!" ),
Emphasis( \!"Effect Leverage\!" ),"
boxcoxstring,
"Run(:Name(\!"",
colListYBoxCox[i],
"\!")<< {Lack of Fit( 0 ), Plot Actual by Predicted( 0 ),
Plot Regression( 0 ), Plot Residual by Predicted( 0 ),
Plot Effect Leverage( 0 ), Box Cox Y Transformation( 1, Save Best Transformation( 1 ) ), Show VIF( 1 )},
boxcoxstring = Concat( boxcoxstring, ");" );
Eval( Parse( boxcoxstring ) );
Wait( 0 );
boxcoxwindow << Close Window;
stephen_pearson
Oct 6, 2014
Solution
Regards,
Stephen
Y(";
boxcoxstring,
"Effects,
boxcoxstring,
"Run(:Name(\!"",
colListYBoxCox[i],
Wait( 0 );
joeldomo
Aug 20, 2014
Hi stephen_pearson,
Just what i need 'Box Cox Y Transformation( 1, Save Best Transformation( 1 ) )'. Yes i'm running thru multiple selections for this option and its now processing without manual intervention. Thanks
ian_jmp
Jun 23, 2011
FYI, here's an alternative that does not require you to build a string. This way, the syntax checking and highlighting in the editor is retained. If you make as many mistakes as I do, that's useful.
NamesDefaultToHere(1);
numericCols = dt << getColumnNames("String", "Numeric");
// Build a function to do what's needed . . .
getBestBoxCox =
Function({numCol}, {Default Local},
		// Open the fit model lauch dialog
		fmDialog = dt << Fit Model(
							Y( Eval(numCol) ),
							Effects,
		// Run the desired model ('fmAnalysis' is a reference to the analysis layer of the report window)
		fmAnalysis = fmDialog << runModel;
		// Close the launch dialog
		Report(fmDialog) << closeWindow;
		// Ask for the transformations
		fmAnalysis << Box Cox Y Transformation;
		// Get a reference to the little red triangle for the transformations
		lrt = Report(fmAnalysis)["Box-Cox Transformations"] << getScriptableObject;
		// Save the best transformation
		lrt << saveBestTransformation;
		// Close the report window
		Report(fmAnalysis) << closeWindow;
// Use the function on the required columns . . .
for(c=1, c<=NItems(numericCols), c++, getBestBoxCox(numericCols[c]));
