BookmarkSubscribeRSS Feed
antoinesofradir
Apr 26, 2013
[JSL] Recover variable value from another script
Hello !
In my first Script i defined a variable ... I would like now to recover this variable in my second Script :
How can i do ?
this example show my problem:
First Script :
Variable = 1 ;
Include("C:\Second Script.jsl");
Second Script :
If( Variable ==1, Data Table ... )
Thanks for your help !
pmroz
Jun 23, 2011
Solution
Re: [JSL] Recover variable value from another script
If you aren't using namespaces or "names default to here(1)" then all variables will be global.
If you are using namespaces or names default to here(1), then if you preface the variable with two colons it will be treated as a global variable.
First Script :
::Variable = 1 ;
Second Script :
If( ::Variable ==1, Data Table ... )
pmroz
Jun 23, 2011
Solution
First Script :
::Variable = 1 ;
Second Script :
antoinesofradir
Apr 26, 2013
Merci beaucoup !
