ABI
Jun 23, 2016
JSL: Populate Fit Model's "Effects" with a List of columns (some with nesting)
Let's say that I have the following:
colList = {"Day","Sample[Day]", "Subsample[Sample,Day]"};
And I would like to use this colList above to populate the Effects of a Fit Model:
myModel = Fit Model(
	Y( :Response ),
	Effects( ????? ),
	//....other stuff after this
I've tried a couple of things, and haven't had any success.
If I just have one column that doesn't have any nesting, and I set singleColName = colList[1], then I can get it to work by doing this:
Effects(Eval(Column(dt, singleColName)));
But the full list, and the nesting in particular, is causing all kinds of headaches (i.e., I've tried converting the list of column names into a list of column references, but the nesting doesn't play well with this approach).
Thanks!
Jun 22, 2012
Solution
Re: JSL: Populate Fit Model's "Effects" with a List of columns (some with nesting)
When I have issues with getting the JMP functions to resolve to what I need, I will drop back to creating a literal string of exactly the code I want and then Eval(Parse()) the literal string.  Here is an example similar to what you need to do:
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
colList = {":Lot_ID", ":lot_id[:Wafer ID in lot ID]"};
value = collist[1];
For( i = 2, i <= N Items( collist ), i++,
	value = value || "," || collist[i]
Eval(
	Parse(
		"myModel = Fit Model(
	Y( :PNP1 ),
	Effects( " || Value ||
	Personality( \!"Standard Least Squares\!" )
1 REPLY
Jun 22, 2012
Solution
value = collist[1];
Eval(
	Parse(
	Y( :PNP1 ),
