Thierry_S
Community Trekker
JSL Newb Question #3: How to refer to specific columns using ":column1" input?
Hi JMP Community,
It's me again. This time, I have reached another roadblack in my attempt to build a simple column renaming script:
Specifically, I'm now able to extract list of columns using the Column Dialog window. This yields a list that looks like this:
srcx = {:Column 1, :Column 2 01, :Column 2 02, :Column 2 03};
Where srcx is a list variable containing the source columns I'd like to use. You'll notice that the columns name are preceded by a colon, as expected. However, when I try to use these column names, I cannot figure out how to use them in the expression srcx [1]  << Set Name ("Example");
Any help is appreciated.
Cheers,
TS
Thierry R. Sornasse
Re: JSL Newb Question #3: How to refer to specific columns using ":column1" input?
Here is the approach I would take
column(srcx[1])<< set name ("Example")
