JSL New Formula Column
joeldomo
Aug 20, 2014
How do i script these keyclicks. With a numeric column, right click to access 'New Formula Column' -> 'Distributional'->'Johnson Normalizing'
What is the basic rule to script these options in the GUI? If i can be directed to a documentations that would be great! Thanks
-Rgds, Joel
Jun 22, 2012
Solution
New Formula Column is not function that has been added to JSL. That is, as far as I can see.  How I would get what you are asking for, is to use the Distribution Platform to generate the new column
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
obj = Distribution( Column( :CO ) );
obj << Fit Distribution( JohnsonSu( Save Transformed ) );
obj << Close Window;
The pointer to the documentation for this is:
     Help==>Scripting Index==>Distribution==>Fit Distribution==>Save Transformed
Jun 22, 2012
Solution
joeldomo
Aug 20, 2014
Hi txnelson,
Thanks. I'm ok with the added overhead of a distribution plots to get what i want if there is no direct access to the 'save transformed' clicks as in the gui.
pmroz
Jun 23, 2011
Another way to get at the scripting for this function is:
1. Perform the operation manually on the table (i.e. New Formula Column' -> 'Distributional'->'Johnson Normalizing)
2. Click the red triangle next to the table name and select Copy Table Script
3. Open up a script window and paste the script in
4. Scroll down to the bottom and you'll see something like this (using the Cities.jmp dataset as an example)
	New Column( "Johnson Su[CO]",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Formula(
			ArcSinH( (:CO - 3.46504509514207) / 2.33960293388985 ) *
			1.77414644201164 + (-2.38210320696422)
So, if you want to script this separately you can say
dt = open("$sample_data/Cities.jmp");
dt << New Column( "Johnson Su[CO]", Numeric, "Continuous",
		Formula(
joeldomo
Aug 20, 2014
Hi Pmroz,
I got your points. Because of data volume, it should be more productive for me to script what i can. I'm interested in the transform formula and getting it by '<<get formula' with the objective of applying it to do back transformation to my volume data.
