JSL Fit Distribution ( <type> )
fugalnc
Nov 12, 2015
I'm trying to create a distribution plot from a column of data and fit a continuous distribution to it. The type of distribution I want to fit is variable, but known within the script. I can't for the life of me figure out how to pass a variable as the type of distribution to fit in Fit Distribution()
So far I've tried
fit_type = "Normal";
Distribution(
	Column( :data ),
	Fit Distribution( fit_type )
As well as
Distribution(
	Column( :data ),
	EvalExpr( Fit Distribution( Expr(fit_type) ) )
And even
string_expr = "Fit Distribution ( " || fit_type || " )";
Distribution(
	Column( :data ),
	EvalExpr( Expr( string_expr ) )
But none of these work. Any ideas out there?
Jun 22, 2012
Solution
Here is one way to do it:
Eval(
	Substitute(
			Expr(
				Distribution(
					Continuous Distribution( Column( :NPN1 ), Fit Distribution( __fit_type__ ) )
		Expr( __fit_type__ ), Parse( fit_type )
Jun 22, 2012
Solution
Eval(
	Substitute(
			Expr(
				Distribution(
fugalnc
Nov 12, 2015
That works. Seems more convoluted than it should be.
I have a Distribution() window with multiple Continuous Distribution() in it, and putting the Substitute around it all works well.
Thanks!
