BookmarkSubscribeRSS Feed
gianpaolo_polsi
Community Trekker
Mar 23, 2016
JSL FIT MODEL Two-Factor Response Surface
Good morning
i would like implement for my JSL a FIT MODEL with "Two-Factor Response Surface Model",
but i havent found ny specific JSL command to do that.
someone can help me
here the code i implemented.. but is incomplete for the FIT MODEL section....
Clear Globals();
Clear Log();
// code to choose among all opened tables which one will be selected for the analysis
OpenDT = List();
For( i = 1, i <= N Table(), i++,
	Insert Into( OpenDT, Data Table( i ) )
dlgDT = Dialog(
	"Please select Data Table for analysis",
	VList( selectDT = List Box( OpenDT ) ),
	HList( Button( "OK" ), Button( "Cancel" ) )
Show( dlgDT );
If( dlgDT["button"] == 1,
	Remove From( dlgDT, N Items( dlgDT ) );
	Eval List( dlgDT );
Current Data Table( selectDT[1] );
cd = Column Dialog(
	Var = collist( " select Response >>", MinCol( 1 ), MaxCol( 1 ) ),
	Hlist( "" ),
	Ref = Collist( " Select Predictors >>", MinCol( 1 ) ),
	Hlist( "" ),
	Hlist( "" ),
	mypareto = Check Box( " Show results's Pareto ", 1 ),
	Hlist( "Number of recursive trees -> ", forest = EditNumber( 10 ) ),
	Vlist(
		Hlist( "" ),
		Hlist( "" ),
		Hlist( "select top predictors ", myrank = EditNumber( 5 ) ),
//declaration of global variables
Response = cd["Var"]; //(Response Variable) ok
Predictor = cd["Ref"]; //(Predictor Variable) ok
Fsize = cd["forest"]; // number of tree to run
pareto = cd["mypareto"];
rank = cd["myrank"];
risultato = New Table( "Tree Table",
	Add Rows( 0 ),
	New Column( "Y", Character, "Nominal" ),
	New Column( "Term", Character, "Nominal", Set Property( "ID Column", 1 ) ),
	New Column( "Number of Splits", Numeric, "Continuous" ),
	New Column( "SS", Numeric, "Continuous" ),
	New Column( "SS 2", Character, "Nominal" ),
	New Column( "Portion", Numeric, "Continuous" ),
tree = Expr(
	partitioning = Partition(
		Y( Response( 1 ) ),
		X( Eval( Predictor ) ),
		Split History( 1 ),
		Informative Missing( 1 ),
		Validation Portion( 0.33 ),
		Minimun Size Split( 5 ),
		Column Contributions( 1 ),
		Go
	part = Report( partitioning )["Column Contributions"][Table Box( 1 )] <<
	Make Combined Data Table;
	part << select where( :Number of Splits == 0 );
	part << delete rows;
	partitioning << close window();
	part << set name( "Parts" );
	risultato = Data Table( risultato ) << Concatenate(
		Data Table( part ),
		Append to first table
	Close( part, "no save" );
For( i = 1, i <= Fsize, i++,
	tree;
If( Pareto == 1,
	Current Data Table( risultato );
	Pareto Plot(
		Cause( :Term ),
//create Ranking Table
Summary_Rank = Data Table( risultato ) << Summary(
	Group( :Term ),
	output table name( "Bootstrap Ranking" ),
Data Table( Summary_Rank ) << Sort(
	By( :N Rows ),
	Order( Descending ),
	replace Table,
x = N Rows( Summary_Rank );
Data Table( Summary_Rank ) << New Column( "Rank", numeric, , formula( Sequence( 1, x, 1 ) ) );
Data Table( Summary_Rank ) << select where( :Rank <= rank );
Column( 1 ) << set selected( 1 );
tempDt = Summary_Rank << Subset( columns( :Term ) );
predictor = Column( 1 ) << get values();
Close( tempDt, "no save" );
// declaration VarExpr variable
varExpr = {};
//------------------------------------------------FIT MODEL Two Factore Response Surface -------------------//
// parse word '& RS' into predictors variablee
For( i = 1, i <= N Items( predictor ), i++,
	Insert Into( varExpr, Parse( ":Name(\!"" || predictor[i] || "\!")" || Char( "& RS" ) ) )
FIT_MODEL = Fit Model(
	Y( Response( 1 ) ),
	Effects(
		(Eval( varExpr )),
	Emphasis( "Effect Leverage" ),
	Run( Profiler( 1, Confidence Intervals( 1 ), Arrange in Rows( 6 ), ), Show VIF( 1 ) )
FIT_MODEL;
Gianpaolo Polsinelli
Jun 22, 2012
Solution
Re: JSL FIT MODEL Two-Factor Response Surface
I think what you are asking for is resolved using this example below:
predictor = {"X1","X2","X3","X4"};
varExpr = {};
	For( k = i, k <= N Items( predictor ), k++,
 		Insert Into( varExpr, Parse( ":Name(\!"" || predictor[i] || "\!")" || Char( " * " ) || ":Name(\!"" || predictor[k] || "\!")" ) )
Jun 22, 2012
You can find a good example of a two factor response surface model in the "Fitting Linear Models" book:
     Help==>Books==>Fitting Linear Models
Once you have generated your model interactively, from the red triangle in the output display, you can request to "Save Script".  It will provide you with the JSL you need to run your analysis.
gianpaolo_polsi
Community Trekker
Mar 23, 2016
Thank yu Jim for your answer,
it seems there is not a quick method to have the on  Effects the Response Surface conditions: (like below example)
X1 RS
X2 RS
X3 RS
X4 RS
X1*X1
X1*X2
X1*X3
X1*X4
X2*X2
X2*X3
X2*X4
X3*X3
X3*X4
X4*X4
by my script i was able to create X1 RS,X2 RS, X3 RS, X4 RS,
but now i need to create by separate script  the multiplication factors ......
Dan_Obermiller
Apr 3, 2013
The best scripter writer for JMP is JMP itself. As Jim stated, build your model interactively and then use the red triangle to save the script. It shows you how it needs to appear in your JSL script:
Fit Model(
Y( :Y ),
Effects(
:X1 & RS,
:X2 & RS,
:X3 & RS,
:X4 & RS,
:X1 * :X1,
:X1 * :X2,
:X2 * :X2,
:X1 * :X3,
:X2 * :X3,
:X3 * :X3,
:X1 * :X4,
:X2 * :X4,
:X3 * :X4,
:X4 * :X4
Dan Obermiller
Jun 22, 2012
Solution
varExpr = {};
gianpaolo_polsi
Community Trekker
Mar 23, 2016
just GREAT!!!, thanks Jim
