BookmarkSubscribeRSS Feed
terapin
Jun 23, 2011
JSL Data Table Summary
I was wondering if it is possible to select the data from additional columns when programming a data table Summary command in JSL that occur for the specific statistic that is called?  For instance,
in the following code I am determining the maximum growth value for each date.  I would like to also grab the Hour, or other variables, corresponding to when the maximum growth value was located for each date. Is it possible to do that with the Summary command in JSL?  If not, what might be another easy way to do this?  Thanks.
dtMax = dt << Summary( Group( :Date ), Max( :Growth) ) );
