minion
JMP18: Python: jmp.Datatable: HowTo get column names without converting to pandas dataframe
Trying to create a new column in a jmp.Datatable and check if it already exists.
Need to get list of column names
Re: JMP18: Python: jmp.Datatable: HowTo get column names without converting to pandas dataframe
The data table is an iterable collection of columns.
import jmp
dt = jmp.open(jmp.SAMPLE_DATA + 'Big Class.jmp')
col_names = [ x.name for x in dt]
print(col_names)
Resulting in
['name', 'age', 'sex', 'height', 'weight']
frank_wang
Re: HowTo get column names of jmp.Datatable without converting to pandas dataframe
Hi
One sample from JSL index
n = dt << Get Column Names();
Show( n );
CNames = dt << Get Column Names( Continuous );
Show( CNames );
SNames = dt << Get Column Names( String );
Show( SNames );
心若止水
Here is the method I normally use to determine if a specific column is or is not in the data table
dt =
// Open Data Table: Big Class.jmp
// → Data Table( "Big Class" )
If( Try( :mycolumn << get name, "" ) == "",
	New Column( "mycolumn" )
minion
Thanks for the inputs.
My bad for not mentioning that was trying to do it in the python environment
Sample code below
import jmp
import jmputils
dt = jmp.current() # get current datatable
dt.new_column('colA', jmp.DataType.Character)
Want to check if colA exists before creating a new one
You can always fall back to jsl using jmp.run_jsl
CNames = jmp.run_jsl('''
Data Table( "Powered by Python" ) << Get Column Names( Continuous, String );
Or you could maybe loop over the columns check them with col_obj.name
import jmp
dt = jmp.open(jmp.SAMPLE_DATA + "Big Class.jmp")
print(dt[0].name)
Comparing column names might not be that easy in JMP and you might want to use something like << Has Column with jmp.run_jsl (data table : message column exists(colname)? - JMP User Community)
import jmp
print(col_names)
Resulting in
From which it is a simple check to see if the name is in the list.
if 'age' in col_names:
    print('found age')
