Bill_McN
JMP14 calling up Legend using Filter - takes too long
Using JMP14.3 but same issue has occurred on JMP12 and multiple PC's.  Have a file with 30K columns, but when I try and apply a Legend for a simple X-Y chart there is a 1~3 min delay in PC responding.  Tried removing all formula, blank columns and makes no difference. When I look up the same filters for group etc, there is no delay. Anyone know what can be done to resolve this delay?
thanks in advance  Bill
Ryan_Gilmore
Re: JMP14 calling up Legend using Filter - takes too long
Hi Bill,
Do you have the same problem if you use the global data filter (Rows > Data Filter)?
What platform are you using to create the graph?
How many rows in the table?
Bill_McN
No global Data filter (Local Data Filter) has a fast response..
Issue is when I use Fit Y by X and add a Legend.  I can add grouping and use filter without an issue.
This table is quite small with about 89K rows, and 30K columns.
Ryan_Gilmore
I would suggest contacting JMP Technical Support to see if they can assist.
Bill_McN
Thanks Ryan.  I have reported it as a problem
