BookmarkSubscribeRSS Feed
OneNorthJMP
Community Trekker
JMP14.2 Stack Column with condition "Contain"
I used JMP13 with stack column with condition "Contain". But when i swith to JMP 14.2, this function is not there anymore. Can anyone confirm why this function is missing? This function is very helpful when i want to stack multiple column with certain condition with "contain" expression. Please help.
gzmorgan0
Re: JMP14.2 Stack Column with condition "Contain"
I think what you want is now listed under Show Filter.  Once you select it, the filter box (with looking glass) appears and the pull down menu includes contains. See the picture below.
gzmorgan0
OneNorthJMP
Community Trekker
Thanks for the tips.
