h_lazar
JMP12 no normalize in new formula column?
I was super excited to see the new formula column feature in JMP12. However, it is sadly lacking the capability to normalize data by a number. Too often we receive data in raw format and need to normalize to some more user friendly value. Do you know how many clicks it takes to create column and enter the formula? I know it can be scripted but adding this as an option in the new formula column to normalize by some constant would be large time saver for doing on the fly analysis. Am I missing the location of this option? If not, is there a place for suggestions? I would like to add this.
Also I found a small issue where the keyboard shortcuts for changing from arrow to select (pressing the s button) does not change it in custom DOE design windows. This feature is also needed for easily journaling things. Is there a place to report bugs?
thanks
H
