BookmarkSubscribe
robot
Community Trekker
JMP11 - Subscript Not Working
I am trying to create a group of columns that will represent the propagation of ramp function.  To do this, I am using the below formulas.  Although the formula syntax seems correct, the formula is not working for rows before 665.  Any suggestions, or workarounds?  I have commented the suspected error.  I am using JMP11.
// Propagating Ramp Functions:
dt = New Table( "Formulas Not Working",
  Add Rows( 25000 ),
  New Column( "RAMP 01",
  Numeric,
  Continuous,
  Formula( If( Row() < 601, 0, If( Row() < 4441, Lag( :RAMP 01, 1 ) + 1 / 3840, If( Row() < 5001, 1, Lag( :RAMP 01, 5000 ) ) ) ) )
  New Column( "RAMP 02",
  Numeric,
  Continuous,
  Formula(
  If(
  Row() < 601, :RAMP 02[601, Empty()],
  Row() == 601, :RAMP 02[4377, Empty()], // I suspect this subscript function is not working, although syntax is correct and Row(4377) has values.  Any ideas?
  Row() < 665, Lag( :RAMP 02, 1 ) + 1 / 3840,
  Row() < 4441, Lag( :RAMP 01, 64 ),
  Row() < 5001, :RAMP 02[4440, Empty()],
  Lag( :RAMP 02, 5000 )
  New Column( "RAMP 03",
  Numeric,
  Continuous,
  Formula(
  If(
  Row() < 601, :RAMP 03[601, Empty()],
  Row() == 601, :RAMP 03[4377, Empty()],
  Row() < 665, Lag( :RAMP 03, 1 ) + 1 / 3840,
  Row() < 4441, Lag( :RAMP 02, 64 ),
  Row() < 5001, :RAMP 03[4440, Empty()],
  Lag( :RAMP 03, 5000 )
  New Column( "RAMP 04",
  Numeric,
  Continuous,
  Formula(
  If(
  Row() < 601, :RAMP 04[601, Empty()],
  Row() == 601, :RAMP 04[4377, Empty()],
  Row() < 665, Lag( :RAMP 04, 1 ) + 1 / 3840,
  Row() < 4441, Lag( :RAMP 03, 64 ),
  Row() < 5001, :RAMP 04[4440, Empty()],
  Lag( :RAMP 04, 5000 )
  New Column( "RAMP 05",
  Numeric,
  Continuous,
  Formula(
  If(
  Row() < 601, :RAMP 05[601, Empty()],
  Row() == 601, :RAMP 05[4377, Empty()],
  Row() < 665, Lag( :RAMP 05, 1 ) + 1 / 3840,
  Row() < 4441, Lag( :RAMP 04, 64 ),
  Row() < 5001, :RAMP 05[4440, Empty()],
  Lag( :RAMP 05, 5000 )
  New Column( "RAMP 06",
  Numeric,
  Continuous,
  Formula(
  If(
  Row() < 601, :RAMP 06[601, Empty()],
  Row() == 601, :RAMP 06[4377, Empty()],
  Row() < 665, Lag( :RAMP 06, 1 ) + 1 / 3840,
  Row() < 4441, Lag( :RAMP 05, 64 ),
  Row() < 5001, :RAMP 06[4440, Empty()],
  Lag( :RAMP 06, 5000 )
ms
Super User ms
Re: JMP11 - Subscript Not Working
It seems like JMP evaluates the formulas in row-order and at first evaluation of e.g. row 601 there are not (yet) any values in cells in row 602 and beyond.
Rerunning of formulas should do it:
Wait(1); // let the first evaluation finish!
dt<<rerun formulas;
robot
Community Trekker
Hi MS,
Thanks for the help.  I was not able to get the function to work from scripting alone.  I eventually got the formula to work by editing the annotated row to reference another column, and then changing it back.  It worked after that.
