jfo
jfo
JMP11 Space Filling Load Constraints Greyed Out?
Hi - new here, and running into a problem on loading constraints in space filling designs. Using the Space Filling DOE dialog in JMP11, there are options to load/save constraints, but I can find no way to make them not greyed out and unselectable. What am I doing wrong?
Jeff_Perkinson
Re: JMP11 Space Filling Load Constraints Greyed Out?
You're not doing anything wrong. Those items should be probably removed from the menu instead of just being grey because they are never available.
I'll make note of it and see if we can get that done for a future release to avoid the confusion.
Sorry!
-Jeff
-Jeff
