shashikale
JMP v12 using script to capture only predication profile graph
Im newbie for JMP tool.I need help wrt to capturing the predication profile graph in html.
Here is what Im trying to do.
I have created jmp file with all my data and created fit model which displayed actucal by predicted plot,scaled estmiates.etc and prediction profiler.
my use case is through command line i want to invoke the xyz.jmp file which will launch xyz.jmp in background and using some mean(script) i want to captured the prediction profiler output only in html which i will display in my dashboard report or site.
is it possible if so can some one please help me how.some pointers will highly appericiated.
Thanks,
Re: JMP v12 using script to capture only predication profile graph
Here is a simple example of outputting the Profiler to an HTML file......you just need to change the "path/to" in the Save Interactive HTML message to a correct path on your computer.
dt:age << modeling type( continuous );
fm = dt << Fit Model(
	Y( :age ),
	Effects( :height, :weight ),
	Emphasis( "Effect Leverage" ),
	Run(
		Profiler(
			1,
			Confidence Intervals( 1 ),
			Term Value(
				height( 62.55, Lock( 0 ), Show( 1 ) ),
				weight( 105, Lock( 0 ), Show( 1 ) )
		:age << {Summary of Fit( 1 ), Analysis of Variance( 1 ),
		Parameter Estimates( 1 ), Scaled Estimates( 0 ), Plot Actual by Predicted( 1 ),
		Plot Regression( 0 ), Plot Residual by Predicted( 1 ),
		Plot Studentized Residuals( 0 ), Plot Effect Leverage( 1 ),
		Plot Residual by Normal Quantiles( 0 ), Box Cox Y Transformation( 0 )}
Report( fm )["Prediction Profiler"] << Save Interactive HTML( "path/to/example.html" );
